For some reason I have not been able to make a diagonal wall... for example when I go to draw a room, I can only make a square or rectangle shaped room but not a triangular or other shaped room, or a bay window. Why can't I make a diagonal line
Hello,
You may use these tool to draw roomes with different shapes. And when you draw the walls with the arch not rectangle, please press 'Ctrl' while drawing:)
