The following are the new features of this update, click on the title to view the detailed tutorial
[General Function]
View or search tutorials when design
Optimize the view manager with display settings
Add import tips for uploading CAD files as floor plan
The Custom Furniture features is now compatible with Multi-floor function
[Interior Modeling 2.0 ]
Add the Modeling Guide as a beginner's guide to interior modeling
Add the Loft modeling function
Add the Curved Array modeling function
Add the Split function for line segment
Add the Component function to modify the same models in batches
Support invert selection command using the shortcut key (Command/Ctrl+i)
Add Custom Flip function
[Customize Ceiling, Wall, Floor ]
Customize Ceiling, Wall and Floor now supports the use of material brush
Customize Ceiling and Floor function has expanded the extrusion size range to more than 2000mm
[Render]
Add the Cabinetry lighting template
Support viewing renders in the custom lighting interface
The VR mode can now be opened for the web browser on desktop
Add a new 2:1 aspect ratio for normal rendering
