Updated Functions:
1.【General Features】
1.1【Function】Added automatic wainscot models
1.2【Function】Measurement tool supported in 3D and roam views
1.3【Function】Supported setting door pocket for single side
2.【Custom Furniture】
2.1【Custom Furniture】The new custom furniture just got launched!
In Custom Furniture, you can design cabinets, closets, shelves and other furniture easily. Various components and parameters give you flexibility in designing custom furniture.
3.【Interior Modeling 2.0】
3.1【Interior Modeling 2.0】Added group list to manage faces and models efficiently
3.2【Interior Modeling 2.0】Supported automatic grouping after using the array function
3.3【Interior Modeling 2.0】Supported 3D text wrapping input, and now can be moved and rotated flexibly
4.【Rendering&Video】
4.1【Render】Panorama added 4K resolution and can be redeemed with points
4.2【Render】Supported to upload your own 2:1 image and covert it into a spherical image as the environment for rendering
4.3【Render】Supported adding text and images in the panorama editing
4.4【Render】Supported deleting images in the preview window of the design interface
4.5【Video】Supported video setting of depth of field effect
4.6【Render-Member Exclusive】Render retouch supported to save the edited image as a new image
4.7【Render-Member Exclusive】Render retouch added crop in free size
Detailed Introduction:
1.1【Function】Added wainscoting model
1.2【Function】Measurement tools supported in 3d and walkthrough views
1.3【Function】Supported setting single side door pocket
The new custom furniture just launched!
In Custom Furniture, you can design kitchen cabinets, closets, shelves and other furniture easily. Various components and parameters give you flexibility in designing custom furniture.
*Note: Please be aware that the custom furniture function does not support the multi-floor for the moment. If you have multi floors or a basement in your design, you will not be able to enter the Custom Furniture environment, nor further edit the cabinet you built.
1.Where to enter the Custom Furniture (beta)?
You can enter it through the Cutstomize catalog on the left.
2.How to design custom furniture?
Let us take a kitchen cabinet as an example. Choose between the products and parts catalog on the left to form the general layout, from the base unit, to the wall unit and also the cabinet with sinks, etc.
3.How to generate countertop, top molding and baseboard for a cabinet?
After designing the layout, you could generate the countertop, the top molding or the baseboard for the cabinets. You can also adjust the styles and materials of these countertops and moldings.
4.How to adjust the parameters of the cabinet and door?
For each custom model, you can adjust the parameters on the right. You could double-click to enter a model and select each panel and board.
3.1【Interior Modeling 2.0】Added model grouping list
3.3【Interior Modeling 2.0】Supported 3D text wrapping input, and move and rotate freely
4.【Rendering&Video】
4.1【Render】Added panorama 4K resolution rendering
4.2【Render】Supported the conversion of the uploaded location image into a spherical image
4.3【Render】Supported adding text and pictures in panorama
4.4【Render】Supported for deleting pictures in the image window of the design interface
4.5【Video】Supported video setting depth of field effect
The depth of field effect can make the picture more spatial, increase the contrast between reality and fiction, and make the effect more realistic. Enter the advanced mode of the video rendering function, and turn on the "Depth of Field Effect" on the right. Once you scroll down the interface, you can manually adjust the "Depth of Field Effect".
4.6【Render-Member Exclusive】Supported edited image to save as
4.7【Render-Member Exclusive】Edit image to add free crop function
